Compile Aurix samples on Tasking environment
User19313
5 replies posted 5 questions asked First reply posted
Hello All,
I have got Tasking compiler (and IDE) installed. I have downloaded sample code from Infineon github for Aurix controllers.
Is there any simple method to compile these sample projects on Tasking IDE?
Is there anywhere documentation available which would help me in compiling the sample code?
I have tried it but it gives lot of compilation errors. I have sorted out errors related to include paths.
Any guidance in this regards is highly appreciated.
Thank you.
Shailendra
cwunder
100 solutions authored 5 likes given 50 likes received
Which development environment are you using and for which AURIX device?
1) AURIX Development Studio v1.1.10?
2) Tasking VX-Toolset for TriCore v6.3r1?
3) Infineon Bifaces where you select the toolchain via config.xml?
User19313
Dear Cwunder
Thanks for your reply.
You are right.
I haven't used BIFACES.
I am just trying to compile sample code from github (https://github.com/Infineon/AURIX_code_examples)
I am flexible to chose any TC2X.
Thanks & regards
Shailendra
teoBits
5 sign-ins 100 replies posted 50 replies posted
Hello Shailendra,
If you are using AURIX™ Development Studio, you can directly import the examples from the studio using the tool File >> Import... >> Infineon >> "AURIX Development Studio Project", select "Infineon Code Examples Repository" and select the code example to be imported.
By doing this, the AURIX™ Development Studio will automatically import all the needed include pathes and everything would work fine!
About the documentation your are asking for, for each code example in the repository there is a dedicated training tutorial which can be found here AURIX™ Trainings.
Furthermore, if you are looking for a training on how to use the AURIX™ Development Studio, take a look at the Getting Started guide!
hope that helps,
teoBits
User19313
Hello teoBits
My question was more related to importing the sample in Tasking IDE and not in Aurix development suite.
Sorry for not being precise.
Shailendra
