AURIX™ Forum Discussions
User21958
I was trying out forcing TRAPs on TC364, by reading and writing from an invalid address 0x30000000
I found that the write caused a BusError Class 4 TRAP with TIN 3, this is a Data Access Asynchronous error
When running on TC364 Eval board with DAS debugger attached I only got this TRAP raised the first time the memory write was done after a reset. The TRAP was not raised again until I had reset from the debugger.
A read from the same address raised a BusError Class 4 TRAP with TIN 2, Data Access Synchronous error.
Does anyone know why the Async error (Class 4 TIN 3) seems to only get raised one time after reset ?
dw
Hi User21958,
There is a training PPT for Tracp Recognition. Could you please try below experiment under ADS platform?
https://www.infineon.com/dgdl/Infineon-AURIX_CPU_Trap_Recognition_1_KIT_TC397_TFT-Training-v01_00-EN...
dw
