Clarification on the Time latency
nsyed
5 likes given 100 sign-ins 50 sign-ins
I am using TC377 in my project, Can you please clarify for Core 0 to read data from DSPR0, DSPR1 & DSPR2 ?
Any reference to the data sheets will be helpful ?
Yuva
250 replies posted 250 sign-ins 100 solutions authored
Yes, as Aurix has open memory architecture, core 0 can access DSPR1 and DSPR2 as well but note there will be latency as the access happens through SRI instead of local access.
Yuva
nsyed
Hello Yuva,
Can you please clarify what will be te time penalty/latency if the Core 0 reads data from DSPR1 and DSPR2 vs DSPR0 .
µC_Wrangler
50 solutions authored 100 sign-ins 25 likes received
Check out this table on page 187 of AURIXTC3XX_um_part1_v2.0.pdf:
Table 71 CPU Accesses: Stall cycles for local and SRI resources
nsyed
Thanks for sharing the information. The cycles listed in Table 71 are fcpux/fsri cycles ?
µC_Wrangler
The table lists CPU stall cycles.  For most applications, fCPU = fSRI.
