AURIX™ Forum Discussions
satyanarayana
First question asked Welcome!
Hi, We are using SAK-TC333LP-32F300FAA(100 pin -TQFP) micro controller. I need following information
1)How many PWM inputs can be capture at at time using capture block.
2)How many many total capture pins are available.
3)What is the difference b/w Hall capture, High speed capture, Trap capture,T12 capture.
4) Can i use all Hall capture, High speed capture, Trap capture,T12 capture for capturing pwm inputs.
Jeremy_Zhou
10 solutions authored 10 likes given 100 replies posted
Hi @satyanarayana ,
Thank you for your interest in Infineon's products and for the opportunity to serve you.
-- The TC333 contains the CCU6 module which consists of two identical kernels CCU60 and CCU61, and each part has three capture pins and three hall capture pins.
-- Actually, I'm not very clear with this question, so I was wondering if you can clarify it again.
BR,
Jeremy
µC_Wrangler
100 sign-ins 25 likes received 25 solutions authored
Don't forget the GTM TIM inputs - you can use those 16 channels too.
