Hi all,
We was develop software using the KIT_A2G_TC397_24V_GTW, we have Ethernet stack up and run with the normal frame. However, we want to enhance our feature on the jumbo packet feature. But we did not received any jumbo frame while we did it in another TC377 TFT board. I appreciate any suggestion/idea to figure out the root cause.
Truong
AURIX
ispn:25782:1:0
l1:314:1:0
Hi Truong,
Have you enabled below bit, and how you do the test? Do you have enabled it in both sides?
dw
Hi dw,
Yes, I have enabled that bit. We are setting our ECU <---> PC's LAN port in the peer to peer topology. We also enable jumbo packet support on PC as well. We have the same testing setup and it works on TC377TP TFT board.
Hi Truong,
Do you mean TC377TP TFT board works for jambo packet?
If it works, then you can refer to the configuartion of code of TC377TP TFT board.
dw
Hi DW,
Both board having Ethernet stack up and run, but the TC397 24V GTW doesn't receive any jumbo frame. I would say from the software configuration point of view, both software are the same. There is a small difference is that the board TC397 24V GTW have the ethernet switch between MCU and Ethernet Phy. I have tried but cannot find any information about them except for an example code of the TC397 24V GTW.
Hi Truong,
The code of 24V gateway application is as below, could you please check if you already understand below source code?
Hi DW,
It seems that this link is only for Infineon's engineer, may you check again as I cannot access it.
Thank you,
Truong
Hi dw,
I have downloaded the project in these link and yes, we was referred to those project, but didn't success to receive jumbo frames.
HI
Please register myICP to access the source:https://www.infineon.com/dgdl/Infineon-MyICP_Guide_registration_for_customers-ATI-v01_00-EN.pdf?file...
