First question : How can I disable ECC safey error in infineon TRICORE TC39XX
I used to disable it in TC27 using this cocde:
/* Deactivate ECC safety errors */
Mcal_ResetENDINIT();
FLASH0_ECCRP0.B.ECCORDIS |= IFX_FLASH_ECCRP_ECCORDIS_MSK;
FLASH0_ECCRP1.B.ECCORDIS |= IFX_FLASH_ECCRP_ECCORDIS_MSK;
Mcal_SetENDINIT();
now I'm tying to disable it on TC39XX with this code DMU_HF_ECCC.B.ECCCORDIS = 0x01
; but it's not working
Should I set PECENCDIS
and DECENCDIS
flags ?
Second question when enabling ECC, why can't I read the flash memory ? I thought it will just not use ECC checking ?
Aurix
DMU_HF_ECCC is the register for DF0. The register for PFx is inside of CPUx. As already described, e.g. for PF0 set CPU0_FLASHCON1.B.MASKUECC = 01B
For second questions, if the flash is erased and not programmed then no valid ECC information is available which result in an uncorrectable ECC error.
Dear salina,
Please check if Set FLASHCON1.B.MASKUECC = 01B will fix your problem.
In AURIXT3XX_um_part1_v2.0.pdf, you can find FLASHCON1 MASKUECC's description.If a local PFLASH uncorrectable ECC error occurs, then the error is globally disabled for any requesting master reading the local PFLASH.
dw
