Can it get any 3phase motor control example or guideline document?
leekings
25 replies posted 25 sign-ins 10 questions asked
Hello. Aurix Forum.
i'm using TC367DP Starter kit and i'm going to make 3 phase BLDC motor control program.
i have 2 questions
1. My first  goal is to make U peak state(current flow from U phase High FET and goes to V, W phase Low side FET  with samely divided state) in U-V-W , 3-phase inverter.
I use 6 -input PWM controlled Gate driver. so i need to control 6 inverter FET's gate input.
Is there any guideline or related document, or sample code with ILLD? and can i get them?
2. what is the difference between PWMHI and PWMBC interface?
thank you in advance!
Di_W
Please apply access the Motor application code here.
Di_W
