Hello Infineon,
I want to know the Node ID of the received rx interrupt.
I initialized node 0~2 of CAN0 with rx interrupt.
Is there any way to know the Node ID of a received packet?
uint8_t rxCANData[3][64];
void canIsrRxHandler(void)
/* Clear the "RX FIFO 0 new message" interrupt flag */
IfxCan_Node_clearInterruptFlag(g_mcmcan.canDstNode.node, IfxCan_Interrupt_rxFifo0NewMessage);
/* Received message content should be updated with the data stored in the RX FIFO 0 */
g_mcmcan.rxMsg.readFromRxFifo0 = TRUE;
/* Read the received CAN message */
IfxCan_Can_readMessage(&g_mcmcan.canDstNode, &g_mcmcan.rxMsg, (uint32*)&g_mcmcan.rxData[0]);
/* Increment the counter confirming to the source node that the previous message has been received */
g_isrRxCount++;
uint32_t length = IfxCan_Node_getDataLength(g_mcmcan.rxMsg.dataLengthCode);
uint8_t node_id = ???;
// For example
memcpy(&rxCANData[node_id], g_mcmcan.rxData, length);
#define NUMBER_OF_CAN_FD_CASES 3
void initMcmcan(void)
* CAN module configuration and initialization:
* - load default CAN module configuration into configuration structure
* - initialize CAN module with the default configuration
IfxCan_Can_initModuleConfig(&g_mcmcan.canConfig, &MODULE_CAN0);
IfxCan_Can_initModule(&g_mcmcan.canModule, &g_mcmcan.canConfig);
* Source CAN node configuration and initialization:
* - load default CAN node configuration into configuration structure
* - assign source CAN node to CAN node 0
* - initialize the source CAN node with the modified configuration
IfxCan_Can_initNodeConfig(&g_mcmcan.canNodeConfig, &g_mcmcan.canModule);
g_mcmcan.canNodeConfig.nodeId = IfxCan_NodeId_0;
g_mcmcan.canNodeConfig.rxConfig.rxMode = IfxCan_RxMode_fifo0;
g_mcmcan.canNodeConfig.rxConfig.rxFifo0Size = NUMBER_OF_CAN_FD_CASES;
g_mcmcan.canNodeConfig.interruptConfig.rxFifo0NewMessageEnabled = TRUE;
g_mcmcan.canNodeConfig.interruptConfig.rxf0n.priority = ISR_PRIORITY_CAN_RX;
g_mcmcan.canNodeConfig.interruptConfig.rxf0n.interruptLine = IfxCan_InterruptLine_0;
g_mcmcan.canNodeConfig.interruptConfig.rxf0n.typeOfService = IfxSrc_Tos_cpu0;
g_mcmcan.canNodeConfig.pins = NULL; // conpig pins Later
IfxCan_Can_initNode(&g_mcmcan.canDstNode, &g_mcmcan.canNodeConfig);
* Destination CAN node configuration and initialization:
* - assign destination CAN node to CAN node 1
* - initialize the destination CAN node with the modified configuration
g_mcmcan.canNodeConfig.nodeId = IfxCan_NodeId_1;
g_mcmcan.canNodeConfig.interruptConfig.rxf0n.interruptLine = IfxCan_InterruptLine_1;
g_mcmcan.canNodeConfig.nodeId = IfxCan_NodeId_2;
g_mcmcan.canNodeConfig.interruptConfig.rxf0n.interruptLine = IfxCan_InterruptLine_2;
/* Initialization of the RX message with the default configuration */
IfxCan_Can_initMessage(&g_mcmcan.rxMsg);
Hi GY,
Please refer to User Manual Interrupt Signalling Register i
ISREGi (i=0-3)
For Node i, there are 16 interrupt type and will be flagged here, so you could know which node has interrupt.
dw
Ifx_CAN_N *node1_Pointer;
IFX_INTERRUPT(canIsrRxHandler, 0, ISR_PRIORITY_CAN_RX);
uint8 can_ch;
if (node1_Pointer->ISREG == g_mcmcan.canDstNode.node->ISREG) {
can_ch = CAN_CH1;
else if (node2_Pointer->ISREG == g_mcmcan.canDstNode.node->ISREG) {
can_ch = CAN_CH2;
else if (node3_Pointer->ISREG == g_mcmcan.canDstNode.node->ISREG) {
can_ch = CAN_CH3;
node1_Pointer = IfxCan_getNodePointer(g_mcmcan.canNodeConfig.can, g_mcmcan.canNodeConfig.nodeId);
Hi GY,
Thanks for your reply, does it work? Hopefully get your confirm.
dw
I am going to modify the code below and test it.
I don't have a test board right now.
I will answer the test result after receiving the board this month or next month.
node2_Pointer = IfxCan_getNodePointer(g_mcmcan.canNodeConfig.can, g_mcmcan.canNodeConfig.nodeId);
node3_Pointer = IfxCan_getNodePointer(g_mcmcan.canNodeConfig.can, g_mcmcan.canNodeConfig.nodeId);
uint8 can_ch;
if (node1_Pointer->ISREG.B.RXF0N) {
can_ch = CAN_CH1;
node1_Pointer->ISREG.B.RXF0N = 0;
else if (node2_Pointer->ISREG.B.RXF0N) {
can_ch = CAN_CH2;
node2_Pointer->ISREG.B.RXF0N = 0;
else if (node3_Pointer->ISREG.B.RXF0N) {
can_ch = CAN_CH3;
node3_Pointer->ISREG.B.RXF0N = 0;
