I am using the CAN0 Node 2 on a KTI_A2G_TC397_3V3_TFT Evalboard and I got a permanent CAN Bus Off.
Used PINs (10.2/10.3) and Autosar Konfiguration seems to be correct. Does anybody has got this problem with this board also?
BR
Bastian
Hi, I has been able to solve the problem after comparison with the integrated example from github. The Tx Pin 10.3 has to be set to Alternate 6 instead of Alternate 5.
Please see this pdf for P20.7/8 pin settings for MCMCAN. The example code is here.
Hi, thanks for the feedback. I used the Pin settings but unfortunately it doesn't solve my problem.
Hi, could you please use the example code first without Autosar?
Hi, this is actually the plan to see differences in the init phase and the config of the Can Controller and pins. I will reply with the results of the test.
Hi BastTutt, all the code is in last post of github. For special pin settings, please refer above 2.pdf already posted.
good
