Jun 09, 2017
03:06 AM
Jun 09, 2017
03:06 AM
Dear sir
I use Infineon TC1782 and my complier is TASKING.
In my Application. I need to Calculate the time the code runs. so i find the introduction in the help contents.it say Select C/C++ Compiler>Debugging and Enable Static profiling.
In the help document:
Menu entey
1.Select C/C++Compiler> Debugging
2.Enable or disable Static profiling
3.Enable or disbale one or more of the following Gen......
for ......
for function times
4.optionally,when you selected function timers,
i have try my best,but i can't achieve the result.
So I will ask below question
1:Can it Calculate the time the code runs?
2:how do i do?for know the time the code runs.
Menu entey
for ......
for function times
04:13 AM
Jun 14, 2017
04:13 AM
Hi sangyangyang,
for just measuring one function I would recommend to use the System timer
dt = STM0_TIM0.U;
myfoo();
dt = STM0_TIM0.U - dt;
Cheers, Martin
dt = STM0_TIM0.U;
myfoo();
Cheers, Martin
