AURIX™ Forum Discussions
User20623
Hi guys,
I'm using TC275 and ADS 1.3.0 and I would like to disable/suspend core 1 and core 2 at startup sequence...
In case that I use IFX_CFG_CPU_CSTART_ENABLE_TRICORE1 within IfxCpu_CStart0.c define and clear it to 0 I'm getting following error:
ltc E120: expression evaluation error in "task1": address of symbol "__USTACK1" (IfxCpu_CStart1.o) could not be evaluated
ltc F019: unrecoverable error: fatal locate error
Now I'm wondering how can I start only one core?
Matej
User21658
i have exactly the same problem.
Did you find any solution for this?
