mehul
01:52 AM
- Email to a Friend
Hello Sir
I need a technical support on Infineon controller
which we are using in Audi project .
we are unable to find the value of CCNT Counter (which is always 0)
Controller name : TC334LP
CPU : CPU0_CCNT
Already the CPU0_CCTRL L 0x0000000002 enabled and configured .
Could you explain how i can get the value of the CCNT ?
I want to find execution time of the function .
So i have to use CCNT
11:16 PM
- Email to a Friend
You can refer to the CPU_Perf_Counters_1_KIT_TC397_TFT example in the ADS. You need to use mfcr/mtcr for reading and writing the registers. If you still facing the issue, please share your code snippet.
mehul
03:27 AM
- Email to a Friend
Hello
Im using predefined code as present in IfxCpu.h as Im using :
IfxCpu_resetAndStartCounters(IfxCpu_CounterMode_normal);
my_function();
after keeping continue Run to the SW ,and checking the value of in Debug window for
CPU0_CCNT SFR register ,which is always zero..
11:48 PM
- Email to a Friend
This is not expected. Could you also check the value returned by IfxCpu_stopCounters after execution of my_function?
