Dear All,
There are 8 CAN on TC397, if user want to wakeup TC397 by CAN interface.
Which pin should be connected and how to configure it?
E-John
Aurix
- can
- can wakeup
- tc397
Generally, the main core will be standby and leave SCR waiting for CAN wake up. So the configure could be a switch that is the main core will initialize CAN module after wakeup. SCR gets CAN wake up and then wake up main core, then SCR related ports could be disable or be set sth else.
Hi E-John, Please refer to TC3xx User Manual Section 49.17 WCAN filter
Hi dw,
from doc "AURIXTC3XX_um_part2_v2.0.pdf".
It describes that every CANRXDx, x from A to G can be set to WCAN Rx
But I see "Infineon-TC39x-DataSheet-v01_00-EN.pdf",
Some CAN RX pins are not matched in p3501 of "AURIXTC3XX_um_part2_v2.0.pdf". (see attachment Px.y_RXDz.png)
1. Is this diagram just for illustration?
2. It just wants to tell us that any CAN RX(Port A to Port G, Node1 to Node4) of any model's Tricore(TX397, TC377, or others...), any Package(LFBGA-516, LFBGA-292)supports wake-on filter?
Dear John,
If you open AURIXTC3XX_um_part2_v2.0.pdf on page 49-359 2021-02 v2.0.0, you can see 49.17.5.2.1 Input/Output function Selection in Ports.
P33.10 / WCANRXDA
P33.7 / WCANRXDB
P33.13 / WCANRXDC
P33.5 / WCANRXDD
P33.2 / WCANRXDE
P14.1 / WCANRXDF (1)
P33.12 / WCANRXDG
Above 7 pins can be selected by MODPISEL0.WCANRXDIS which is routed to WCANRXD
Otherwise, in 49.10 section, you can see:
The SCR has a maximum of 16 general purpose I/O ports with 8-bit peripheral I/O lines that are shared with the 32-bit peripherals I/O lines. It is organized into two parallel ports. Internally within the SCR, these ports are always referred to as SCR_P00 and SCR_P01. Here, within the SCR, the terms SCR_P00 and SCR_P01 do not refer to the main-SoC ports P00 and P01. Instead, they are actually mapped to pins in ports P33 and P34.1 in this platform.
Table 624 Pin assignment for Ports in SCR
SCR Ports Main SoC Ports / Pins
SCR_P00.0 - SCR_P00.7 P33.0 - P33.7
SCR_P01.0 P34.1
SCR_P01.1 - SCR_P01.7 P33.9 - P33.15
dw
Hi dw,
The WCAN kernel register names described in this chapter(49.17) will be referenced in the Standby Domain
Internal Target Specification by the module name prefix “WCAN_”.
From my understanding,
If the P33.10 is configured to WCANRXDA for SCR, it is no more the Main SoC CAN01_RXDD, is my understanding correct?
it is clear, understood, thanks.
