CAN configuration - TC399
Nareshkumar119
50 sign-ins 10 questions asked First solution authored
Hi All,
I want to configure CAN module in TC399 Micro-Controller,
I want to use same node for transmit and receive, I configured the transmit part, but in reception part i am facing issue,
receive interrupt is not generating, can you share me any example code for this , i want to generate the interrupt for Receive in same node.
