CAN bootloader for TC234LP
leonng
First like received First like given 10 questions asked
Hi there,
I'm designing to use the UAD2pro for the CAN bootloader, but there is something wrong.
When I use "Triboard with TC23x (DXCPL) via UAD2pro", it list:
 When I use "Triboard with TC23x (Memtool/CAN)", it list:
I check the DAS connection, it's working.
The used CAN pin is correct (P14.0&1) and can send a CAN signal.
The TRST pin can be set to low.
What else can I check? Thank you.
Leon
Di_W
Dear user,
https://www.pls-mc.com/downloads/datasheets/UDE_Manual.pdf
For UAD2pro, which offers fastest target access via JTAG, cJTAG, DAP, DAP over CAN Physical Layer (DXCPL), SPD (Single Pin DAP) via CAN, SWD, ASC and CAN with build-in ESD protection.
Is it OK for JTAG and DAP? Please refer to above user manual for usage. Otherwise, there is an application note  AP32442 DXCPL DAP over CAN Physical Layer  for your reference (downloaded from myICP).
dw
leonng
Sorry for the typo, DASDAP is working.
we didn't design an interface for JTAG, I can't check JTAG.
Di_W
leonng
Thank you.
From my understanding, Pin14.0&1 is directly used for the bootloader. It is unnecessary to use TLE9251V to generate a CAN signal, otherwise, there will be an error.
