AURIX™ Forum Discussions
Olsch001
Hi there,
I use the Evaluation Board KIT_A2G_TC366_5V_TRB_S and want to use 14 CAN dedicated Rx Buffers with interrupt.
My problem is that only buffers 0-7 get an interrupt.
For the buffers 0 -13 the data is written into the CAN message RAM and the flags for new data ND0 - ND13 are also set, but as I said, an interrupt is only triggered for buffers 0-7.
I hope someone has an idea and can help me with this problem.
dw
Hi Olsch,
It looks like you hit the root cause! Could you please try to use below instead
if(node->NDAT1.U&mask)
    return True;
 Expect to receive your good news.
dw
dw
Hi Olsch,
M_CAN supports 64 dedicated Rx Buffers. IRi.DRX is set when a msg is stored into the Rx Buffer.
NDAT1i NDAT2i is set after last word of a matching received msg written.
Please check if filter masked data? or buffer full?  Attached related register for your reference.
dw
Olsch001
Hi dw,
thanks for your reply.
I found my issue in the iLLD library ifxCan.c in function boolean IfxCan_Node_isRxBufferNewDataUpdated(Ifx_CAN_N *node, IfxCan_RxBufferId rxBufferId).
If a buffer greater than 7 is used, tempVar never evaluates to TRUE. For example if buffer number 8 is used node->NDAT1.U & mask evaluates to 0b 0001 0000 0000  and after the boolean (unsigned char) cast it evaluates to 0b 0000 0000.
    uint32  mask;
    boolean tempVar;
    if (rxBufferId < IfxCan_RxBufferId_32)
        mask    = (1U << rxBufferId);
        tempVar = (boolean)(node->NDAT1.U & mask);
        return tempVar;
    else
        mask    = (1U << (rxBufferId - 32));
        tempVar = (boolean)(node->NDAT2.U & mask);
        return tempVar;
dw
Hi Olsch,
    return True;
dw
Olsch001
Hi dw,
Yes, this works as well as the following.
        tempVar = (boolean)((node->NDAT1.U >> rxBufferId) & 0x01);
        return tempVar;
