User18757
5 questions asked First like received First reply posted
i created a project with the Bifaces multiple .elf example, which works fine.
Based on that, i would like to use the same source files for conditional compiling for e.g. 2 seperate elf files , how would you setup this in the .xml config file with the correspondant definitions as compiler flag
to build those two elf with one build initiation?
Greetings
