AURIX™ Forum Discussions
User17842
Hello everyone!
I have just started learning embedded programming. So far, I practiced using Atmel microprocessors and recently I got Aurix starter kit. So, I have started learning TC297 B step, but it is much more complicated compared to Atmel microprocessors. I could not get basic frameworks
and customer documentation yet because my registration on Infineon was not approved yet. Now I am stuck and don't know how to move further. I would like to know if there are any other sources such as sample codes, manuals provided by advanced users and etc to learn and practice this board? Any help would be appreciated.
Best regards, Dastan.
VincentWan
50 replies posted 5 sign-ins First like received
Hi, when you have access to the documentation etc, you can follow below steps:
To quickstart on how to have a code running on the starterkit, you would need to download & install the following tools first, you can also refer to the Quick Start guide document:
1. Free TriCore Entry Tool Chain https://free-entry-toolchain.hightec-rt.com
2. BIFACES https://myicp-dmz.extra.infineon.com/sites/microcontrollers-aurix_customer_doc/_layouts/IFX.iShare.M...
3. iLLD https://myicp-dmz.extra.infineon.com/sites/microcontrollers-aurix_customer_doc/_layouts/IFX.iShare.M...
4. Quick Start guide https://myicp-dmz.extra.infineon.com/sites/microcontrollers-aurix_customer_doc/_layouts/IFX.iShare.M...
You need to register @ myinfineon.com if you are a 1st time user.
User17842
Thank you very much!
User21730
5 replies posted 5 questions asked First reply posted
Hi VincentWan,
Thank you for your assistance, I am trying to get started with the TriBoard TC233LP, and I need iLLD documentation I have already access to the documentation but couldn't find it (3. iLLD https://myicp-dmz.extra.infineon.com...fAllItems.aspx)
Thank you
Badr
teoBits
100 replies posted 50 replies posted 25 replies posted
Another option would be to use AURIX™ Development Studio (ADS), the free (not for commercial purposes) IDE dedicated to AURIX, supporting AURIX TC2xx and TC3xx at the moment.
You can get the AURIX™ Development Studio here: AURIX™ Development Studio and get inspired by numerous Trainings from here: AURIX™ Trainings.
From ADS, you can also download tons of free trainings:
To import a code example, use the import function of the AURIX™ Development Studio: File >> Import... >> Infineon >> "AURIX Development Studio Project", select "Infineon Code Examples Repository" and select the code example to be imported.
(iLLDs are embedded in ADS, therefore each project imported or newly created has automatically the correct version of iLLDs needed for your device)
If you are not familiar with Eclipse based IDE’s checkout the Getting Started guide!
hope it helps,
teoBits
User22150
I have the board TC 297, I would need the layout of the board to understand which pins of the microcontroller are connected with the led.
Please could you help me ?
5219.attach
Thank you very much
ilm
MoD
250 sign-ins 25 likes received 50 solutions authored
The LEDs on this boards are from left to right:
P33.6, P33.7, P33.8, P33.9; P33.10, P33.11, P33.12, P33.13
You can download the manual for this board from http://myicp.infineon.com
