Automotive secure gateway sample code
hawky
25 sign-ins First reply posted First question asked
We bought KIT_A2G_TC377_SEC_GTW but I just couldn't find the sample code for this board. Could you please help me with it? If there is one, can I get it by pm? I would be very grateful to you.
Thank you in advance.
Nambi
500 replies posted 50 likes received 5 likes given
hawky
Thank you so much for your reply @Nambi.
I was just wondering can't I use the ILLD for this board? We are in the NDA process now but it will probably take a while. I just found a sample code for Mcmcan, however, it is not completely for this board. If there is a sample code specifically for this board with ILLD, where can I find it? If not do I need MCAL to develop such an ECU project with simple can bus gateway functionality?
Best Regards.
Nambi
We don't see an ILLD-based example of the gateway board. You can refer to the below link to adapt the required examples based on ILLD.
https://github.com/Infineon/AURIX_code_examples
Best Regards.
