May 16, 2020
10:57 PM
May 16, 2020
10:57 PM
I'm debugging the TC399B, and get a reset that's given from the SMU and FSP. (PSA)
BUT, I cannot catch the point in the SW it occurs, I have no view of the stack or PC, nor have the reset reason for this issue.
How can I collect the reason? which register holds the data?
May 17, 2020
05:34 AM
May 17, 2020
05:34 AM
Have a look at the Trap System chapter in the TriCore Architecture Manual 1.6.2 volume 1.
May 17, 2020
06:01 AM
May 17, 2020
06:01 AM
Only at the TC39cB RM v1.4, and AURICTC3xx RM v1.4
May 17, 2020
06:09 AM
May 17, 2020
06:09 AM
In general, I only recommend having the SMU reaction configured to reset for a select few alarms, such as the watchdog recovery timers. Nothing captures the trap cause or PC across a system reset. It's much easier to track things down if your SMU reaction is NMI, and then the NMI handler can cause a system reset.
What is the alarm that caused the reset?
May 17, 2020
08:18 AM
May 17, 2020
08:18 AM
I have no idea, it just says that the SMU is to blame, couldn't find any register that can explain the the why or what?
May 17, 2020
08:36 AM
May 17, 2020
08:36 AM
After the reset, SMU_ADx will have a snapshot from before the reset. That might give you a clue like "SRI bus error", but the details will be lost.
If you can change the SMU reaction to NMI, your NMI handler can capture the details.
May 17, 2020
09:15 AM
May 17, 2020
09:15 AM
All SMU_ADx regs stay 0 after the reset occurs:
How can I set the NMI trap?
May 18, 2020
06:09 AM
May 18, 2020
06:09 AM
Diving a bit deeper it might be something to do with the ECC correction?
May 18, 2020
06:33 AM
May 18, 2020
06:33 AM
The SMU reaction to each alarm is configured in SMU_AGiCFj: see Table 529 SMU Alarm Configuration. The three bits are spread out over the three registers SMU_AGiCF0..2. As an example, to set the SMU reaction to an SRI bus error (ALM7[17]) to NMI (5 per Table 529):
// NMI = 5 = 1 0 1 binary
SMU_AG7CF0.U |= (1 << 17);
SMU_AG7CF1.U &= ~(1 << 17);
SMU_AG7CF2.U |= (1 << 17);
May 18, 2020
06:42 AM
May 18, 2020
06:42 AM
UC_wrangler wrote:
The SMU reaction to each alarm is configured in SMU_AGiCFj: see Table 529 SMU Alarm Configuration. The three bits are spread out over the three registers SMU_AGiCF0..2. As an example, to set the SMU reaction to an SRI bus error (ALM7[17]) to NMI (5 per Table 529):// NMI = 5 = 1 0 1 binary
Thanks, very helpffu.
So you chose here ALM7[17], how to I know which one to choose?
No, alarm in SMU_ADi reports a fault condition.
From the configuration, it seems that omly AG10 is set by default, for FSP as reset. meaning :
Trying to update it by:
SMU_AG10CF0.U |= (1 << 17);
SMU_AG10CF1.U &= ~(1 << 17);
SMU_AG10CF2.U |= (1 << 17);
creates a weird behavior
May 18, 2020
08:29 AM
May 18, 2020
08:29 AM
The way to interpret this is:
SMU_AG10FSP = 0x00030000 => bits 16 and 17
FSP is asserted for ALM10[16] (Recovery Timer 0)
FSP is asserted for ALM10[17] (Recovery Timer 1)
SMU_AG10CF0 = 0x00000000, SMU_AG10CF1=0x00030000, SMU_AG10CF2=0x00030000
ALM10[16] reaction is 110b (0x6 RESET)
ALM10[17] reaction is 110b (0x6 RESET)
Perhaps the "weird behavior" you are seeing is because the SMU registers are Safety ENDINIT protected, so you need to clear/set that protection to be able to perform a write.
May 18, 2020
09:14 AM
May 18, 2020
09:14 AM
Excellent, so the code is written:
IfxScuWdt_clearSafetyEndinit(safetyWdtPassword);
IfxScuWdt_setSafetyEndinit(safetyWdtPassword);
_isync();
but unfortunately it has no effect over the registers...
May 18, 2020
10:49 AM
May 18, 2020
10:49 AM
Is the SMU locked? Check SMU_KEYS.CFGLCK. Once the SMU is locked, alarm configuration cannot be changed - see 15.3.1.10.1 Register Write Protection.
Sep 24, 2020
04:27 AM
Sep 24, 2020
04:27 AM
Was this solved?
