Oct 13, 2020
11:18 AM
Oct 13, 2020
11:18 AM
I need to find a solution for automated flashing of Aurix TC23xL via miniWiggler V3. Could anyone advise the software tool that has an API or at least command line interface that can be used for this purpose ?
The only tool that handles programming I've found till now is Infineon MemTool - unfortunately seems it can't work without GUI.
Thanks in advance for any hint!
Dominik
Dominik
12:16 PM
Oct 13, 2020
12:16 PM
There is a commercial version of Memtool available from PLS that supports command line scripting.
Oct 13, 2020
10:59 PM
Oct 13, 2020
10:59 PM
Unfortunately when contacted with PLS they stated that miniWiggler is not supported by their software. I'm bind to miniWiggler and need solution that works with it ...
Oct 22, 2020
07:38 AM
Oct 22, 2020
07:38 AM
P&E micro recently announce support for AURIX, you may want to check it out : http://www.pemicro.com/blog/index.cfm?post_id=198
