leekings
25 replies posted 25 sign-ins 10 questions asked
Hello. Aurix team.
I'm using SAK-TC387QP MCU, and made project file.
after setting pinmap via Aurix Pinmapper, i made a code.
After long time, i need to change modify pinmap, so i opened pinmapper, but error happend. like below picture.
i addtach my pinmapper.pincfg file and code and header file.
other projects are opened very well.
can i fix this problem?
thank you.
Di_W
Hi leekings,
Could you try to create a new TC38xA project, and create a .pincfg file together, then copy the content of your pinmapper.pincfg into it. Then try to open the .pincfg again.
dw
Di_W
Hi leekings,
dw
leekings
hello dw.
i made new tc38x project file and success to open pinmapper.
after that, i copied original pinmapper.pincfg file. same error happend.
do i need to copy code&header file too? i tried it, the result was same.
please help.
thank you.
thank you i solved problem.
i do 'rebuild active project'  and it work well
thank you.
