User19495
we are using the Aurix tc27x C-step controller for multiple projects. The newer D-step chips have better availability, therefore it would make sense to switch to D-step for new projects. However I could not find information about what changed between CA step and the current DC step. Does anyone has any documentation about the changes between the revisions of the tc27x chips?
Thanks in advance.
NeMa_4793301
Level 6
Level 6
You can see a list of changes in the errata sheet:
https://www.infineon.com/dgdl/Infineon-TC27x_DC-step-ES-v01_02-EN.pdf?fileId=5546d46269bda8df0169c9d...
Errata sheets for older revisions are on MyICP.
