Aurix TC3xx EVADC result valid flag DMA
_TheCableGuy
First like received First reply posted First question asked
Hello
If the ADC group results are read via DMA, should I expect the result valid flag to be 0xxxxxxxx or 8xxxxxxx on the RAM destination address? At the moment I can see 8xxxxxxx on both source register and destination RAM
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @_TheCableGuy
1) Should I expect the result valid flag to be 0xxxxxxxx or 8xxxxxxx on the RAM destination address?
-- It depends on the situation in you read the GxRESy register, for instance, if the DMA request is activated by a new result, the valid flag should be 0x8xxxxxxx in the RAM destination, otherwise, it should be 0xxxxxxxx.
BR,
Jeremy
Jeremy_Z
Hi @_TheCableGuy
BR,
Jeremy
Many thanks. So in this case the DMA trigger is the ADC end of conversion so 0x8xxxxxx is expected
