AURIX™ Forum Discussions
User18904
5 sign-ins 5 replies posted 5 questions asked
I see in the User Manual in the memory mapping EBU0 could this be used to connect external SRAM?
dw
Hi User18904,
The register region is F840 0000 ~, you can check the reg header file under ADS IDE at below path:
Libraries\Infra\Sfr\TC39B\_Reg\IfxEbu_reg.h
/** \addtogroup IfxSfr_Ebu_Registers_Cfg_BaseAddress
/** \brief EBU object */
#define MODULE_EBU /*lint --e(923, 9078)*/ ((*(Ifx_EBU*)0xF8400000u))
User18904
Thank you for your answer.
Do you mean EBU0 (occupying 64k in memory space) could be used the same way as EBU?
dw
Hi, below is fyi. A200 0000- A7FF FFFF is for EBU.
User18904
I am referring to F840 0000H - F840 FFFFH (64k area). Could it be used the same as A200 0000- A7FF FFFF (96M)?
dw
Hi User18904,
