Hello!
I would like to know if there is any example for TC3XX bootloader available from Infineon, or if anyone could share their implementation. I want to understand better the implementation with AURIX tricore, and flashing over CAN.
Thank you.
Aurix
- aurix
- bootloader
- tc3
Hi
What protocol are you talking about using the flash bootloader you want?
For example, is it KWP-2000 or flash via UDS or another protocol using CAN?
Hi!
I was looking for an protocol related to CAN, could be UDS but not necessarily, any bootloader that will take .hex file from CAN and flash the main memory.
Hi
I am interesting the example for TC3XX bootloader available from Infineon also, The best with UDS, OTA.
Thanks advance.
Any update on this topic?
Hi people,
We could not find any example, we did develop our own bootloader since we could not find any.
Where did you get the proper documentation to develop your own?
Basically reading the datasheet, understanding the data banks and linker script. With that information we created our bootloader application to read CAN requests, save data to specific memory location.
