Samad
50 sign-ins 5 replies posted 5 questions asked
Hi team, We want to measure the ethernet bandwidth of AURIX TC39x. We are using TriBoard TC3X7 TH V2.0 devkit and Ethernet_1 for KIT_AURIX_TC397_TFT default example.
We had implemented LWIPERF in that example. LwIperf server is running on AURIX TC39x side. We were getting only 16Mbps bandwidth if we connect iperf client(linux pc). Later we played with TCP parameters and reached 100Mbps. We tried for 1Gbps but we couldn't achieve it.
Can we have any tips to play with TCP parameters to achieve 1Gbps?
Do you have any examples or tools to measure the ethernet bandwidth of AURIX ?
Or Can you find us a way to prove AURIX TC39x will support 1000Mbps? Help is most appreciated.
Samad.
David_R
100 replies posted 25 solutions authored 10 likes given
Hi @Samad
If you take a look at the specs of the ethernet module in the user manual it states that it supports the desired bandwidth
As the example it's based on the LWIP stack, you can take at look at the documentation to tweak the speed
https://lwip.fandom.com/wiki/Tuning_TCP
https://www.nongnu.org/lwip/2_0_x/index.html
Regards! :1
Samad
Hi @David_R ,
Yes, it is in RGMII 1000Mbps mode only. We want to measure the ethernet bandwidth.
Any standard procedure to do the same? Can we have any implementation ideas to measure the bandwidth?
Note: We are having NDA with Infineon.
Samad.
David_R
Hello @Samad
Looking over the internet i found a guide that gives some recommendations to enhance the throughput, also i don't know if you have the latest iperf version, according to the webpages the version 3.0  has new features
Regards! :1
Samad
Hi @David_R ,
Thanks for your response. The given link is not accessible though we have NDA. Seeking your help in that.
The above suggested latest iperf version seems to be Non-LWIP TCP stack. We want to integrate LWIP iperf in AURIX  right?
Any suggestions regarding LWIP iperf server code? Which version of code to be intergrated?
Samad.
