Amr-khaled-Aziz
5 replies posted 5 sign-ins First reply posted
Hello All,
I am trying to debug using Aurix TC399XP kit, winIDEA debugs successfully.
However, when I try the Tasking c/c++ debugger, it fails with the following error "Loading failed: Flash programming failed, there may be a problem with the flash memory itself."
I am using the latest Aurix Development Studio v1.9.20.
BR,
Erick_G
100 sign-ins 25 solutions authored 50 replies posted
Hi @Amr-khaled-Aziz,
Are you able to flash without debugging?
With this option in the toolbar.
Amr-khaled-Aziz
Hi @Erick_G ,
Yes I am.
BR
Can you share a screenshot of the error?
Erick
Amr-khaled-Aziz
Hi @Erick_G ,
Sure here it is.
Regards!
