Mar 24, 2021
09:44 AM
Mar 24, 2021
09:44 AM
Hi There,
I am currently trying to execute the interrupt on another core but core0.
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/GTM_TOM_Interrupt_1_KIT_TC...
According Explanation to the code
https://www.infineon.com/cms/en/product/promopages/aurix-expert-training/
https://www.infineon.com/dgdl/Infineon-AURIX_GTM_TOM_Interrupt_1_KIT_TC397_TFT-Training-v01_00-EN.pd...
Taking the bare example (cutting the LED Stuff) works just fine.
But switching
to e.g. cpu1
prevents any cpu from servicing this Interrupt.
What I could figure out so far:
The ECC Flag in the SRC_GTMTOM10 is set to 06 when setting the Provider to cpu1.
The ECC Flag in the SRC_GTMTOM10 is set to 00 when setting the Provider to cpu3.
The ECC Flag in the SRC_GTMTOM10 is set to 1C when setting the Provider to cpu0.
The ECC Flag in the SRC_GTMTOM10 is set to 1F when setting the Provider to cpu2. -> There the CPU traps in an error
The ECC Flag in the SRC_GTMTOM10 is set to 19 when setting the Provider to cpu4. -> There the CPU traps in an error
The ECC Flag in the SRC_GTMTOM10 is set to 1A when setting the Provider to cpu5. -> There the CPU traps in an error
For compiling I use gcc.
If there are any questions, please let me know!
BR
Christoph
But switching
timerConfig.base.isrProvider = IfxSrc_Tos_cpu0
to e.g. cpu1
timerConfig.base.isrProvider = IfxSrc_Tos_cpu1
BR
Christoph
09:44 AM
Mar 25, 2021
09:44 AM
Each CPU has its own BIV register (interrupt vector table) and interrupt enable/disable status (ICR.IE).
Do you have an ISR defined on CPU1? What does CPU1's BIV register with your interrupt offset (SRN * 32 bytes) point to?
Are interrupts enabled on CPU1 (ICR.IE)?
Mar 26, 2021
02:23 AM
Mar 26, 2021
02:23 AM
You can also change the used vector table by changing the second parameter of the macro IFX_INTERRUPT:
/* Macro to define Interrupt Service Routine.
* This macro makes following definitions:
* 1) Define linker section as .intvec_tc_.
* 2) define compiler specific attribute for the interrupt functions.
* 3) define the Interrupt service routine as ISR function.
* IFX_INTERRUPT(isr, vectabNum, priority)
* - isr: Name of the ISR function.
* - vectabNum: Vector table number.
* - priority: Interrupt priority. Refer Usage of Interrupt Macro for more details.
IFX_INTERRUPT(interruptGtmTom, 0, ISR_PRIORITY_TOM);
BR,
teoBits
BR,
teoBits
Mar 26, 2021
12:25 PM
Mar 26, 2021
12:25 PM
thanks very much @UC_wrangler and @teoBits. Both of your answers helped me to figure out, what went wrong. In fact it was the Vector Table Number, I did not set correctly. I did not see the connection between vectabNum and CPU number.
So if anyone else struggles with that:
Core0 -> vectabNum 0
Core1 -> vectabNum 1
Core2 -> vectabNum 2
Core3 -> vectabNum 3
(4 and 5 not checked)
BR,
Christoph
BR,
Christoph
