AURIX™ Forum Discussions
Fitz_
First solution authored 5 sign-ins First reply posted
Recentlly, I'm using AURIX TC397's MPU,
I config 7 data MPU regions for each cpu(core0 ~ core5), for core4, protection set 0, region 4 is Write enable,
however, when I debug the program, it run into MPW trap, and DEADD register indicate 0x7000521C is violate the MPW
( I'm sure that SYSCON.PROTEN is set and PSW.PRS is set0)
My question is:  0x7000521C is between [0x70004BC0, 0x70005290) , why it occur trap 1? does this reasonable?
( ps: this phenomenon also happen in core5 when I debug another time )
Fitz_
thanks,  this problem is solved.
i saw PRS is set0 when trap occur, actually it is Set2 before trap.
dw
MPE Memory Protection Error : Data access violating memory protection.
First please remove all the protection to try,  then try to focus if Read Error or Write Error.
Fitz_
At the very beginning, the program runs OK, and i think it is a Write Error
i debug by sigle step, when it run st16.b [a15]0x8, d15, it occur trap, and 0x7000521C is a global varible
dw
Could you please remove the protection? Could you please confirm enabled read and write for protection set 0, region 4?
Fitz_
---1, at the very beginning,  I didn't config any MPU region , and the program runs OK.
---2, i change the region 4 's read permiss to enable, but it seems no difference
dw
Is this code useful? pdf
Fitz_
