Aurix TC377 - ADC Pin Leakage Current
Mayur_M_B
First reply posted First like given First question asked
Dear team,
I kindly request you to provide the per pin leakage current of TC377 (AN pin).
Anupama_A
50 solutions authored 10 likes received 250 sign-ins
Hi @Mayur_M_B ,
It depends on the pin. You can check the pin's pad type from buffer type column in table 2-17 of the Tcx37x Data sheet. Then depending on the pad type, you can check the input leakage current from the respective table, for eg. AN0 is of Class D pad, so for that pin, we can check the leakage current value from table 3-15.
Anupama.
Anupama_A
Hi @Mayur_M_B ,
Anupama.
Hello Anupama,
Thank you for the feedback.
