Sven
10 replies posted 5 sign-ins 5 replies posted
Observation:
- RESAx registers display random values
- RESMx registers remain 0
- EVFLAG register displays 1's for RESEVx /ALEVx
Questions:
- What are the reasons for random content and possible Solution?
- What are the reasons for RESMx remaining 0? Corresponding GLOBRC channels/Modulators were set to run
dw
    g_resultEDSADC = IfxEdsadc_Edsadc_getMainResult(&g_edsadcChannel);
Please refer to EDSADC_1_KIT_TC375_LK in ADS, after initialize setting correctly, above funtion is called for getting result. RESM register contains the result as below.
  return edsadc->CH[channel].RESM.B.RESULTLO;
If result or alarm generated, RESEV/ALEV will be set 1 as below
Sven
thanks, my question is more general - apart of sample. What is the reason for RESM providing random values? Which checkpoints i can put to locate reason & resolve?
dw
First start from the demo code, if your application is changed too much from that, please try to bypass(disable) filters to simplify the process.
dw
