AURIX™ Forum Discussions
User20694
I don't understand the WDT.
After CPU reset, WDTSCON1.REL is set to 0xFFFC.
In this case the period should be 655.35us.
(period = 2^16 - 0xFFFC) * 16384 / 100)
It will take longer to set the value in REL, so it should be reset, but....
VincentWan
50 replies posted 5 sign-ins First like received
Hi
After a reset, CPU0 runs and CPU0 Watchdog Timer starts automatically.
The CPU0 is running @ 300MHz & the WDT is running @ 100MHz divided by 16384, therefore the CPU0 has ample time to service the WDT to prevent reset by setting ENDINIT = 1.
VincentWan
Hi
