Aurix TC333 RTC implementation_Continue
gunasekart
10 replies posted 5 replies posted 10 sign-ins
Hi Team,
am unable to reply to below community link. So, created new one
Solved: Re: Aurix TC333 RTC implementation - Infineon Developer Community
my query is you have mentioned that P33.10 can be connected to external RTC clock. Which Mux I have to select. Also normally crystal having two pins, you have mentioned only one pin what about another pin. It will help if you given any application  note or hardware connection of RTC connection to implement. It is critical to our project now.
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @gunasekart  ,
In the user manual, it contains the code guide.
BR,
Jeremy
TBencher
Level 6
Level 6
25 solutions authored 25 likes received 5 questions asked
I assume it was closed because you did not respond anymore and you actually did not answer the questions asked.
If this is critical now, you would need to tell way more about your project. Or you may opt. for commercial service instead in order to save time.
Best,
TBencher
gunasekart
Understand. we need to implement RTC in our board. but unfortunately, hardware manual /application is not there. How to proceed further.
Jeremy_Z
Hi @gunasekart ,
It doesn't need another pin actually.
BR,
Jeremy
Hi Jeremy,
Thanks for input. My question which function from below table i have to select for RTC clock. As you know each pin will do different function, based on MUX selection, function can be selected.
Jeremy_Z
Hi @gunasekart  ,
BR,
Jeremy
TBencher
Level 6
Level 6
I think we would still need more context. If I am not wrong you did initially asked for the DC source. This question was already answered.
Best,
TBencher
TBencher
Level 6
Level 6
Hi Jeremy,
I am afraid he is still not aware about the SCR stuff. Not sure what he is actually doing.
Best,
TBencher
I can understand SCR, the manual focused on software implementations and registers. In hardware datasheet specification, no much details on RTC. Thats why i requested on RTC implementation connection details. Is it wrong?
TBencher
Level 6
Level 6
no it is not wrong. I just checked the link you provided earlier in the initial chat. There is RTC stated, which is a bit hmmm... .  I assume you will utilize it within one of the TC cores?
Best,
TBencher
TBencher
Level 6
Level 6
Ok,
looks like you have just one TC core available.
Best,
TBencher
gunasekart
Sorry am not getting your point.
Is it possible meeting discussion with your technical representative
TBencher
Level 6
Level 6
Oh,
we are always happy to help. Please go ahead and drop us your contact details to info@tbench-solutions.com.
Please also add project details as needed to understand where you plan to utilize the SCRs RTC. We will then try to find a slot where we can discuss your technical problems.
Best,
TBencher
TBencher
Level 6
Level 6
...in process now...
gunasekart
Hi Team,
Thanks for your response. We are planned to discuss with your technical team. We planned to implement RTC in our design. We need to know the   "Current consumption of the TC333 required to maintain the RTC when the unit is off (or in sleep)". Unfortunately the Datasheet having doesn't have the current consumption details of RTC. Please check and provide the same.
Jeremy_Z
Hi @gunasekart
Yes, the datasheet doesn't provide this current consumption parameter.
BR,
Jeremy
