Feb 21, 2021
11:07 PM
Feb 21, 2021
11:07 PM
I am using TC297 microcontroller with single 3.3V supply mode.
During Internal EVR13 (1.3V Supply with external device) with below mentioned HW configuration it is not working in direct supply in single attempt (VGATE1P - High ).
To work this section properly need to remove the power supply and connect for multiple times then it is generating pulse from VGATE1P and 1.3V generating from complementary MOSFET.
Facing same problem in SMPS and LDO mode. But during external 1.3V supply mode it is working properly
SMPS LDO
HW CFG0 0 1
HW CFG1 0 0
HW CFG2 1 1
HW CFG3 1 1
HW CFG6 0/1 0/1
* 0-Pulldown with 1K
*1-Pullup with 1K
*HW CFG6 tried both the combination
*HW CFG-Hardware configuration
User manual link: https://www.infineon.com/dgdl/Infineon-TC29x_B-step-UM-v01_03-EN.pdf?fileId=5546d46269bda8df0169ca1b...
Please suggest some solution.
SMPS LDO
HW CFG0 0 1
HW CFG1 0 0
HW CFG2 1 1
HW CFG3 1 1
HW CFG6 0/1 0/1
*1-Pullup with 1K
05:10 AM
Feb 24, 2021
05:10 AM
Can you share this part from your schematics?
Feb 25, 2021
05:02 AM
Feb 25, 2021
05:02 AM
Please find the attachment.
Feb 26, 2021
09:40 AM
Feb 26, 2021
09:40 AM
The capacitor C65 should not be assembled, this capacitor is used in e.g. TC237 instead of the MOSFET and the coil.
