May 18, 2021
09:11 PM
May 18, 2021
09:11 PM
Hi Sir,
I am trying to offload CPU by using DMA to send out 40bytes struct on asclin1Tx with DMA. But when I set the TREL of the DMA to be 40. I will always get only 17 bytes at the receiver of the UART.
So, I guess that my DMA must over write my asclin1 TX fifo. I fixed it by breaking the DMA into 16 bytes sections and start the first transaction manually then using TX interrupt to start the next DMA
transfer as 16 bytes sections until all 40 bytes are completely sent.
Is it the correct way to do ? Are there any way for DMA to do not over write the asclin TX fifo?
Thank you very much,
Weetit
Weetit
May 19, 2021
04:21 AM
May 19, 2021
04:21 AM
My guess is that your application is missing connecting DMA to SRC_ASCLIN1TX in the Interrupt Router. That would result in a TX overflow, because DMA needs to wait for room in the ASCLIN TX FIFO before it transfers the next byte. It makes sense that you'd only get 17 in that case: one byte in the output shift register, 16 in the TX FIFO, and the rest overflow.
Share some code and we can help straighten things out.
May 19, 2021
09:04 AM
May 19, 2021
09:04 AM
Thank you very much UC_wranler,
Here is what I do.
Here is what I do.
void initDMA(void)
SRC_ASCLIN1TX.B.TOS=3;
SRC_ASCLIN1TX.B.SRPN=ISR_PRIORITY_ASCLIN1_TX;
SRC_ASCLIN1TX.B.SRE=1;
/* Load default module configuration into configuration structure */
IfxDma_Dma_initModuleConfig(&g_DMA.dmaConfig, &MODULE_DMA);
/* Initialize module with configuration. */
IfxDma_Dma_initModule(&g_DMA.dmaHandle, &g_DMA.dmaConfig);
/* Get/initialize DMA channel configuration for all DMA channels otherwise use &g_Dma.dmaChannel as target */
IfxDma_Dma_initChannelConfig(&g_DMA.dmaChNCfg, &g_DMA.dmaHandle);
/* Set desired DMA channel: Channel 0 is used */
g_DMA.dmaChNCfg.channelId = DMA_CHANNEL_ID;
/* Setup the operation mode/settings for DMA channel */
g_DMA.dmaChNCfg.moveSize = IfxDma_ChannelMoveSize_8bit;
g_DMA.dmaChNCfg.blockMode = IfxDma_ChannelMove_1;
/* Set the number of DMA transfers */
g_DMA.dmaChNCfg.transferCount = (uint16)16; //<--------------------------------- Cannot make it more than 16
/* Execute the DMA transaction with only one trigger */
g_DMA.dmaChNCfg.requestMode = IfxDma_ChannelRequestMode_completeTransactionPerRequest;
g_DMA.dmaChNCfg.hardwareRequestEnabled = TRUE;
g_DMA.dmaChNCfg.requestSource=IfxDma_ChannelRequestSource_peripheral;
/* Setup the specific DMA channel configuration */
IfxDma_Dma_initChannel(&g_DMA.dmaChannel, &g_DMA.dmaChNCfg);
/* Save start address of source and destination buffers, into the Application global variable */
g_DMA.pSourceAddressForDmaTransfer = g_dataForDmaTransfer;
g_DMA.pDestinationAddressForDmaTransfer = (uint32) &ASCLIN1_TXDATA.U;
g_DMA.dmaChNCfg.sourceAddressCircularRange = IfxDma_ChannelIncrementCircular_none;
g_DMA.dmaChNCfg.sourceCircularBufferEnabled = FALSE;
g_DMA.dmaChNCfg.destinationAddressCircularRange = IfxDma_ChannelIncrementCircular_none;
g_DMA.dmaChNCfg.destinationCircularBufferEnabled = TRUE;
g_DMA.dmaChNCfg.operationMode = IfxDma_ChannelOperationMode_continuous;
/* Trigger a DMA transaction via SW request */
static void triggerDMATransfer(void)
/* Set destination and source address data to DMA channel */
g_DMA.dmaChNCfg.sourceAddress = (uint32) g_DMA.pSourceAddressForDmaTransfer;
g_DMA.dmaChNCfg.destinationAddress = (uint32) g_DMA.pDestinationAddressForDmaTransfer;
/* Request start of DMA Transaction channel 0 */
IfxDma_Dma_startChannelTransaction(&g_DMA.dmaChannel);
May 19, 2021
12:51 PM
May 19, 2021
12:51 PM
I don't see anything about ASCLIN initialization.
Is ASCLIN1_FLAGSENABLE.TFLE set?
What's in ASCLIN1_TXFIFOCON.INTLEVEL?
Is ISR_PRIORITY_ASCLIN1_TX equal to DMA_CHANNEL_ID?
This looks a little fishy, because it will try to do all the bytes in one go:
I would try this instead, so that each TXFIFO empty causes one DMA byte transfer:
/* Execute one DMA transfer per trigger */
g_DMA.dmaChNCfg.requestMode = IfxDma_ChannelRequestMode_oneTransferPerRequest;
May 20, 2021
06:13 AM
May 20, 2021
06:13 AM
Hi UC_wranger,
I think I set ASCLIN1_TXFIFOCON.INTLEVEL to 0.
I have try set g_DMA.dmaChNCfg.requestMode = IfxDma_ChannelRequestMode_oneTransferPerRequest; but still no luck.
Here is the init for uart
void init_asc_uart()
IfxAsclin_Asc_Config ascConfig;
IfxAsclin_Asc_initModuleConfig(&ascConfig, &MODULE_ASCLIN1);
ascConfig.baudrate.baudrate = 921600;
ascConfig.interrupt.txPriority = INTPRIO_ASCLIN1_TX;
ascConfig.interrupt.rxPriority = INTPRIO_ASCLIN1_RX;
ascConfig.interrupt.typeOfService = IfxSrc_Tos_dma;
const IfxAsclin_Asc_Pins pins =
NULL_PTR, IfxPort_InputMode_pullUp, /* CTS pin not used */
&IfxAsclin1_RXA_P15_1_IN, IfxPort_InputMode_pullUp, /* RX pin */
NULL_PTR, IfxPort_OutputMode_pushPull, /* RTS pin not used */
&IfxAsclin1_TX_P15_0_OUT, IfxPort_OutputMode_pushPull, /* TX pin */
IfxPort_PadDriver_cmosAutomotiveSpeed1
ascConfig.pins = &pins;
ascConfig.txBuffer = &g_ascTxBuffer;
ascConfig.txBufferSize = UART_TX_BUFFER_SIZE;
ascConfig.rxBuffer = &g_ascRxBuffer;
ascConfig.rxBufferSize = UART_RX_BUFFER_SIZE;
ascConfig.fifo.txFifoInterruptLevel=IfxAsclin_TxFifoInterruptLevel_0;
IfxAsclin_Asc_initModule(&g_ascHandle, &ascConfig); /* Initialize module with above parameters */
May 21, 2021
12:48 AM
May 21, 2021
12:48 AM
did you take a look at the UART_DMA_Transfer_1_KIT_TC297_TFT training and its tutorial?
The training is written for AURIX TC297 but it can be easily ported for your device also.
hope it helps,
teoBits
hope it helps,
teoBits
May 21, 2021
09:18 PM
May 21, 2021
09:18 PM
Hi Teo,
Yes that one is Uart RX to DMA, in this case RX fifo will not be overflowed with the DMA. For my case, DMA to Uart TX. I cannot make DMA wait for the TX fifo, the DMA keep pump the data until UART TX fifo over flow.
The current solution now, it sets DMA move to be 16 as the fifo size and use TX interrupt (set to filo level=0) to start next DMA transfer 16 bytes a time, until all the data is transferred. This works but it is not 100% DMA.
So, I would like to know if it is possible to offload CPU 100% making DMA and UART TX fifo works together.
Weetit
Weetit
May 24, 2021
03:07 PM
May 24, 2021
03:07 PM
Perhaps this helps, this example is for the TC297 but should be basically the same for the TC265. It uses ASCLIN0 and two DMA channels one for Tx and Rx.
I didn't use the iLLD's. To trigger a transmit you can do the following assuming you have the DMA ready:
Here is the ASCLIN file
Scope plot of the output for the first 20 bytes (i have P15.2 connected to P15.3 with an external jumper)
/* Initiate the transmit transfer using the transmit FIFO level flag */
ASCLIN0_FLAGSSET.B.TFLS = 1;
/****** ASCLIN0 PORT Selection ******************************/
/* [0] ATX0:P14.00 ARX0A:P14.01 */
/* [1] ATX0:P15.02 ARX0B:P15.03 */
/* [2] ATX0:P01.13 ARX0C:P01.08 */
/* [3] ATX0:P34.01 ARX0D:P34.02 */
/* [4] ATX0:P13.10 ARX0E:P13.11 */
#define ASCLIN0_PORT 1
#if (ASCLIN0_PORT == 0)
#define IOCR_ALTI asclin_iocr_RxInputSelect_ARXnA
#define ASCLIN0_PD_PIN P14_PDR0.B.PD0 = 0
#define ASCLIN0_TX_PIN P14_IOCR0.B.PC0 = PCx_Output_PushPull_Alt_2
#define ASCLIN0_RX_PIN P14_IOCR0.B.PC1 = PCx_Input_PullUp
#elif (ASCLIN0_PORT == 1)
#define IOCR_ALTI asclin_iocr_RxInputSelect_ARXnB
#define ASCLIN0_PD_PIN P15_PDR0.B.PD2 = 0
#define ASCLIN0_TX_PIN P15_IOCR0.B.PC2 = PCx_Output_PushPull_Alt_2
#define ASCLIN0_RX_PIN P15_IOCR0.B.PC3 = PCx_Input_PullUp
#elif (ASCLIN0_PORT == 2)
#define IOCR_ALTI asclin_iocr_RxInputSelect_ARXnC
#define ASCLIN0_PD_PIN P01_PDR1.B.PD13 = 0
#define ASCLIN0_TX_PIN P01_IOCR12.B.PC13 = PCx_Output_PushPull_Alt_2
#define ASCLIN0_RX_PIN P01_IOCR8.B.PC8 = PCx_Input_PullUp
#elif (ASCLIN0_PORT == 3)
#define IOCR_ALTI asclin_iocr_RxInputSelect_ARXnD
#define ASCLIN0_PD_PIN P34_PDR0.B.PD1 = 0
#define ASCLIN0_TX_PIN P34_IOCR0.B.PC1 = PCx_Output_PushPull_Alt_2
#define ASCLIN0_RX_PIN P34_IOCR0.B.PC2 = PCx_Input_PullUp
#elif (ASCLIN0_PORT == 4)
#define IOCR_ALTI asclin_iocr_RxInputSelect_ARXnE
#define ASCLIN0_PD_PIN P13_PDR1.B.PD10 = 0
#define ASCLIN0_TX_PIN P13_IOCR8.B.PC10 = PCx_Output_PushPull_Alt_2
#define ASCLIN0_RX_PIN P13_IOCR8.B.PC11 = PCx_Input_PullUp
#else
#error "No ASCLIN0 pins defined"
#endif
/* private data */
static volatile uint16 ASCLIN0_errorCount;
static volatile uint16 ASCLIN0_txDmaCnt;
static volatile uint16 ASCLIN0_rxDmaCnt;
void ASCLIN0_Init (void)
uint16 cpuPassword = IfxScuWdt_getCpuWatchdogPassword();
IfxScuWdt_clearCpuEndinit(cpuPassword);
ASCLIN0_CLC.U = 0; /* enable peripheral and allow sleep mode */
(void) ASCLIN0_CLC.U;
/* change the driver strength on the port transmit pin */
ASCLIN0_PD_PIN;
/* Kernel reset */
ASCLIN0_KRST0.U = 0x01;
ASCLIN0_KRST1.U = 0x01;
IfxScuWdt_setCpuEndinit(cpuPassword);
while ((ASCLIN0_KRST0.U & 0x02) != 0x02)
ASCLIN0_KRSTCLR.U = 0x01; /* Clear Reset done flag */
/* ASCLIN0_ATX transmit output */
ASCLIN0_TX_PIN;
/* ASCLIN0 ARX0n receive pin*/
ASCLIN0_RX_PIN;
Ifx_ASCLIN_IOCR iocr = {
.B.ALTI = IOCR_ALTI,
.B.DEPTH = 0, /*0=off, 1 to 63 */
.B.CTS = asclin_iocr_CtsInputSelect_0,
.B.RCPOL = asclin_iocr_RtsCtsPolarity_activeHigh,
.B.CPOL = asclin_iocr_ClockPolaritySyncMode_idleLow,
.B.SPOL = asclin_SlavePolaritySyncModeSlsoIdleLow,
.B.LB = asclin_iocr_LoopBackModeDisabled,
.B.CTSEN = asclin_iocr_CTS_disabled,
ASCLIN0_IOCR.U = iocr.U;
Ifx_ASCLIN_TXFIFOCON txfifocon = {
.B.FLUSH = asclin_txfifocon_Flushed,
.B.ENO = asclin_txfifocon_OutletEnabled,
.B.INW = asclin_txfifocon_InletWidth_1,
.B.INTLEVEL = asclin_txfifocon_InterruptLevel_15,
ASCLIN0_TXFIFOCON.U = txfifocon.U;
Ifx_ASCLIN_RXFIFOCON rxfifocon = {
.B.FLUSH = asclin_rxfifocon_Flushed,
.B.ENI = asclin_rxfifocon_InletEnabled,
.B.OUTW = asclin_rxfifocon_OutletWidth_1,
.B.INTLEVEL = asclin_rxfifocon_InterruptLevel_1,
.B.BUF = asclin_rxfifocon_ReceiveBufferMode_rxFifo,
ASCLIN0_RXFIFOCON.U = rxfifocon.U;
Ifx_ASCLIN_FRAMECON framecon = {
.B.ODD = asclin_ParityType_even,
.B.PEN = asclin_ParityEnable_Disabled,
.B.CEN = asclin_CollisionDetection_Disabled,
.B.MSB = asclin_ShiftDirection_lsbFirst,
.B.MODE = asclin_frameMode_initialise,
.B.LEAD = asclin_LeadDelay_0,
.B.STOP = asclin_StopBit_1,
.B.IDLE = asclin_IdleDelay_0,
ASCLIN0_FRAMECON.U = framecon.U;
Ifx_ASCLIN_DATCON datcon = {
.B.RESPONSE = 0,
.B.CSM = asclin_Checksum_classic,
.B.RM = asclin_LinResponseTimeoutMode_frameTimeout,
.B.HO = asclin_HeaderResponseSelect_headerAndResponse,
.B.DATLEN = asclin_DataLength_8,
ASCLIN0_DATCON.U = datcon.U;
Ifx_ASCLIN_BITCON bitcon = {
.B.SM = asclin_SamplesPerBit_three,
.B.SAMPLEPOINT = asclin_SamplePointPosition_9,
.B.OVERSAMPLING = asclin_OversamplingFactor_16,
.B.PRESCALER = 0,
ASCLIN0_BITCON.U = bitcon.U;
/*this will configure the baud rate to 115200*/
Ifx_ASCLIN_BRG brg = {
.B.NUMERATOR = 71,
.B.DENOMINATOR = 3852,
ASCLIN0_BRG.U = brg.U;
/* Clear all Flags */
ASCLIN0_FLAGSCLEAR.U = 0xFFFFFFFF;
Ifx_ASCLIN_FLAGSENABLE flagenable = {
.B.TFLE = TRUE, /* Transmit FIFO Level */
.B.TFOE = TRUE, /* Transmit FIFO Overflow */
.B.RFLE = TRUE, /* Receive FIFO Level */
.B.RFUE = TRUE, /* Receive FIFO Underflow */
.B.RFOE = TRUE, /* Receive FIFO Overflow */
.B.FEE = TRUE, /* Framing Error */
ASCLIN0_FLAGSENABLE.U = flagenable.U;
/*set up the interrupts that are used */
SRC_ASCLIN0TX.U = TOS_DMA | SRE_ON | SRPN_DMA_CH_ASCLIN0_TX;
SRC_ASCLIN0RX.U = TOS_DMA | SRE_ON | SRPN_DMA_CH_ASCLIN0_RX;
SRC_ASCLIN0ERR.U = TOS_CPU0 | SRE_ON | SRPN_CPU0_ASCLIN0_ER;
/*set the mode of the ASCLIN to operate in*/
ASCLIN0_FRAMECON.B.MODE = asclin_frameMode_asc;
Ifx_ASCLIN_CSR csr = {
.B.CLKSEL = asclin_csr_ClockSource_fASCLINS,
.B.CON = asclin_csr_ClockIsOn,
ASCLIN0_CSR.U = csr.U;
void ASCLIN0_DMA_Init (uint32 *src, uint32 *dst, uint16 trel)
/* DMA Channel 007 used for Transmit */
DMA_SADR007.U = (uint32) src;
DMA_DADR007.U = (uint32) &ASCLIN0_TXDATA.U;
Ifx_DMA_CH_CHCFGR chcfgr_7 = {
.B.TREL = trel, /*Transfer Reload Value */
.B.BLKM = dma_chcfgrxxx_blkm_OneTransferHasOneMove,
.B.RROAT = dma_chcfgrxxx_rroat_ResetAfterEachTransfer,
.B.CHMODE = dma_chcfgrxxx_chmode_SingleMode,
.B.CHDW = dma_chcfgrxxx_chdw_DataBitWidth_8,
.B.PATSEL = dma_chcfgrxxx_patsel_NoPatternCompareOperation,
.B.PRSEL = dma_chcfgrxxx_prsel_HardwareRequestSelected,
.B.DMAPRIO = dma_chcfgrxxx_dmaprio_LowPrioritySelected,
DMA_CHCFGR007.U = chcfgr_7.U;
Ifx_DMA_CH_ADICR adicr_7 = {
.B.SMF = dma_adicrxxx_smf_AddressOffsetIsCHDWx1,
.B.INCS = dma_adicrxxx_incs_AddressOffsetIsAdded,
.B.DMF = dma_adicrxxx_dmf_AddressOffsetIsCHDWx1,
.B.INCD = dma_adicrxxx_incd_AddressOffsetIsSubtracted,
.B.CBLS = dma_adicrxxx_cbls_SourceAddress31to0,
.B.CBLD = dma_adicrxxx_cbld_DestinationAddress31to0,
.B.SHCT = dma_adicrxxx_shct_MoveOperation,
.B.SCBE = dma_adicrxxx_scbe_SourceCircularBufferDisabled,
.B.DCBE = dma_adicrxxx_dcbe_DestinationCircularBufferEnabled,
.B.STAMP = dma_adicrxxx_stamp_NoAction,
.B.ETRL = dma_adicrxxx_etrl_NoInterruptOnLostEvent,
.B.WRPSE = dma_adicrxxx_wrpse_WrapSourceBufferInterruptTriggerDiabled,
.B.WRPDE = dma_adicrxxx_wrpde_WrapDestinationBufferInterruptTriggerDiabled,
.B.INTCT = dma_adicrxxx_intct_InterruptChangingTCOUNTandEqualsIRDV,
.B.IRDV = 0, /*Interrupt Raise Detect Value*/
DMA_ADICR007.U = adicr_7.U;
DMA_TSR007.B.ECH = 1;
/* DMA Channel 008: used for Receive */
DMA_SADR008.U = (uint32) &ASCLIN0_RXDATA.U;
DMA_DADR008.U = (uint32) dst;
Ifx_DMA_CH_CHCFGR chcfgr_8 = {
DMA_CHCFGR008.U = chcfgr_8.U;
Ifx_DMA_CH_ADICR adicr_8 = {
.B.INCS = dma_adicrxxx_incs_AddressOffsetIsSubtracted,
.B.INCD = dma_adicrxxx_incd_AddressOffsetIsAdded,
.B.SCBE = dma_adicrxxx_scbe_SourceCircularBufferEnabled,
.B.DCBE = dma_adicrxxx_dcbe_DestinationCircularBufferDisabled,
DMA_ADICR008.U = adicr_8.U;
DMA_TSR008.B.ECH = 1;
/* Setup interrupt from DMA Channel 7 and 8 when the Move Transaction has finished */
SRC_DMACH7.U = TOS_CPU0 | SRE_ON | SRPN_CPU0_DMA_CH7;
SRC_DMACH8.U = TOS_CPU0 | SRE_ON | SRPN_CPU0_DMA_CH8;
Jun 01, 2021
08:41 AM
Jun 01, 2021
08:41 AM
Hi cwunder,
I will try this Thank you very much.
Weetit
Jun 23, 2021
08:57 AM
Jun 23, 2021
08:57 AM
Can someone explain to me, in words maybe, how the FIFO and the DMA communicate? I see the FIFO overflowing so I get the 17 bytes too, but I just don't see the mechanism that allows the handshaking.
thanks in advance,
Charlie
thanks in advance,
Charlie
Jun 23, 2021
12:21 PM
Jun 23, 2021
12:21 PM
In general: DMA gets fed by the Interrupt Router. So it's a matter of configuring a peripheral to assert an interrupt (aka service request).
In the example cwunder posted, the TX/RX interrupts from the FIFO are enabled setting ASCLIN0_FLAGSENABLE, and then the interrupt feeds DMA by configuring the Interrupt Router via SRC_ASCLIN0TX and SRC_ASCLIN0RX.
Jun 29, 2021
07:14 AM
Jun 29, 2021
07:14 AM
in this line,
TOS_DMA = (1 << 11)
SRE_ON = (1<<10)
but what does SRPN_DMA_CH_ASCLIN0_TX equal? would it be 7, the DMA channel number?
thanks again, Charlie
in this line,
TOS_DMA = (1 << 11)
SRE_ON = (1<<10)
Jun 29, 2021
07:25 AM
Jun 29, 2021
07:25 AM
Correct, the DMA channel for TX is 7 and for RX is 8 for that example.
Jun 29, 2021
09:31 AM
Jun 29, 2021
09:31 AM
I finally got it. Thank you all for the help.
I was trying to start the process of sending by doing this:
DMA_CHCSR047.B.SCH = 1; // start transfers to complete a transaction
which was wrong. It didn't start the FIFO going with the help of the interrupt router.
ASCLIN8_FLAGSSET.B.TFLS = 1;
is what I needed to do.
It was clearly stated in the sample provided. I just didn't comprehend it.
Charlie
Charlie
Sep 02, 2021
04:49 AM
Sep 02, 2021
04:49 AM
hi weetit,
Does your problem has been resolved? I met the same problem, I want to send 32 bytes, but the receiver only got 17 bytes.
If your problem has been resolved, would you share me your solution?
Thank you~
Thank you~
