Aurix TC212 - RSTSTAT EV13 flag is SET after reset
Angkhan-Chiew
I am running my software with my hardware Aurix TC212, but my board is reset randomly without clues. I have 2 hardware boards, tested the same software, 1st board is not reset, 2nd board is reset. In the debugger, RSTSTAT EV13 flag is SET after reset, any idea or hint, which I can continue debug it?
Angkhan-Chiew
Attached Debugger Screenshot
Erick_G
100 sign-ins 25 solutions authored 50 replies posted
Hi @Angkhan-Chiew,
Does this only happens when debugging?
This flag comes from the voltage monitor for external voltage, it could be that the device is getting under the threshold voltage allowed.
You can check the section 8.3.1.7 Voltage monitoring from the user manual for more details.
Erick
Thank you Erick_G.
No, it does happens both debugging and without debugging.
I will check in the user manual as suggestion.
