User17934
I am currenty working with the Aurix Motor Control Kit and the PDF “eMotor Drive Kit for the AURIX product family”.
Unfortunately, Figure 21 on page 27 is not sharp and therefore not usable.
Does anyone know how to get a sharp version of this figure, which is the schematic of the motor PCB.
Jerome
NeMa_4793301
Level 6
Level 6
Hi Jerome. Oops, sorry about that. I've asked for an update. I'm not sure if the app note will get updated, but hopefully we can get at least a PDF of the schematic.
NeMa_4793301
Level 6
Level 6
Hi Jerome. Here's the PDF. Let me know if you have any trouble.
User18504
Hello, is this the kit for the 3 Phase Brushless Motor?
Is it possible to connect the driver board to a different Evaluation Board, for example to TC277_TFT?
NeMa_4793301
Level 6
Level 6
Hmm. It looks like you could, but the analog inputs are mapped very differently, so you'd have to modify the software to match:
TC2x7 Application Kit:
3903.attach
TC234 Motor Control Kit:
3904.attach
User18504
I can make a breakout board to match the pins, this shouldn't be a big problem as I would need also to measure signals.
Thanks for the reply, now the question is if the code from the motor kit can also be ported easily to the TC277.
