AURIX™ Forum Discussions
abhishek-2138
First like received 10 likes given 10 replies posted
In the datasheet for AURIX TC364 MCU, can we disable the internal load capacitors.
Its because if we add external load cap then external & internal load caps will be in parallel.
Or do we need to consider internal load cap while selecting external load capacitor & consider the parallel combination??
Jeremy_Zhou
10 solutions authored 10 likes given 100 replies posted
Hi @abhishek-2138 ,
Thank you for your interest in Infineon's products and for the opportunity to serve you.
1) Can we disable the internal load capacitors?
-- Yes, of course.
2) Do we need to consider the internal load cap while selecting the external load capacitor & consider the parallel combination?
-- It's unnecessary to consider the internal load capacitance if you disable the feature.
Further, I'd like to suggest you refer to the AP56002_Crystal Oscillator Basics note to design an appropriate OSC circuit.
BR,
Jeremy
Jeremy_Zhou
Hi @abhishek-2138 ,
-- Yes, of course.
BR,
Jeremy
