AURIX™ Forum Discussions
User20010
I'm looking for Aurix Instruction set. As I understand it's not the same as Tricore IS. Am I right? I'm asking because I can't find it on the site.
I will be grateful for any help. Thanks
Darren_Galpin
The Aurix instruction set would be a superset, as it would contain TriCore instructions plus any instructions needed for non-TriCore cores in other peripherals. If you are not using peripherals which exercise their own code, then you could consider the Aurix IS to be the same as the TriCore IS.
NeMa_4793301
Level 6
Level 6
Here are direct links to the TC2xx (TC1.6.1) TriCore Architecture Manual:
https://www.infineon.com/dgdl/tc1_6__architecture_vol1.pdf?fileId=db3a3043372d5cc801373b0f374d5d67
https://www.infineon.com/dgdl/tc1_6__architecture_vol2.pdf?fileId=db3a3043372d5cc801374ad9c0653ad9
The TC3xx (TC1.6.2P) has a handful of new instructions, but requires registration on MyICP (as of today, at least).
