User17172
I am working with TC212 board. I need port/pin change interrupt feature in my current project.
My requirement is ISR should be invoked with voltage level change on port/pin.
could you please provide ERU sample code for TC-212.
Thanks in advance.
MoD
50 likes received 500 replies posted 100 solutions authored
Please check the iLLD demos. You can find there the ScuEruDemo. This should help.
teoBits
5 sign-ins 100 replies posted 50 replies posted
Hello diwanker,
You can find a code example project for the ERU here: ERU training code example.
this example also comes with a tutorial, which can be found here: ERU tutorial.
If you are interested in other modules and you want to start programming for AURIX™, you can get the new Integrated Development Environment (IDE) here: AURIX™ Development Studio and get inspired by numerous trainings from www.infineon.com/aurix-expert-training
If you are not familiar with Eclipse based IDE’s checkout the Getting Started guide from here.
Hope it helps,
teoBits
