Aurix Developments studio : pre build configuration
savaninikunj
10 sign-ins First like given First reply posted
Hello Team,
I am using ADS for building example project which is based on iLLD framework , I have imported one of example code from ACV and I have try to build code.
I am suspecting that its not configure for build environments , could you guide me what all need to configure for build code.
Initial I am getting this error during build.
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @savaninikunj
Actually, please confirm the ADS whether support the TC4xx, as this version needs to be applied specifically.
BR,
Jeremy
TBencher
Level 6
Level 6
25 solutions authored 25 likes received 5 questions asked
your image implies you want to compile code for the latest TC4XX device.
I am not not sure whether you are aware of that. Please tell me which
ADS version, which TC version and which ILLD version you are using and please provide your test code.
Best,
TBencher
Jeremy_Z
Hi @savaninikunj
BR,
Jeremy
