Jan 08, 2023
11:44 PM
Jan 08, 2023
11:44 PM
I am trying to find time consumed by a particular block of code. It needs to be done dynamically by the code.
Is there any way where I can see the number of clock of cycles consumed between 2 breakpoints in IDE itself?
And is there any way same can be accessed in the code?
12:22 AM
Jan 09, 2023
12:22 AM
Hi @Neetigya ,
Thank you for your interest in Infineon Semiconductor products and for the opportunity to serve you.
1) Is there any way where I can see the number of clock of cycles consumed between 2 breakpoints in IDE itself?
-- No, I'm afraid the ADS supports the feature.
BR,
Jeremy
