User18504
How can I run the GitHub Examples on a TX27X Eval Board?
Is there some configuration that I must change?
cwunder
On the Help tab in the AURIX Development Studio you will find a selection tab called getting started. If you open this it describes how to import a project from GitHub.
teoBits
100 replies posted 50 replies posted 25 replies posted
since this question has been answered on another thread, I'll link here the thread for reference: https://www.infineonforums.com/threads/10720-GTM-using-ILLD?p=24634&viewfull=1#post24634
You can create a new project for the TC27X device and copy-paste the GitHub example's files inside, together with the needed instructions on the Cpu0_Main files. This ensures that in the new project you have everything correctly configured for your device.
After that, check if in your board the pinouts are different and modify the example accordingly.
teoBits
