Aurix Development Studio
Ana0211
10 likes given 5 replies posted 5 likes given
Is there any way to debug without downloading the elf file ? I would like to just attach my debugger to the running software, is this possible using Aurix Development Studio?
Thank you,
Ana
Di_W
Hi Ana,
Thanks for question! ADS is using Tasking free debugger tool, you can refer to below pdf for Getting Started Intro.
.elf is to be downloaded before debugging. You can also use free PLS UDE STK 2021 as below shown, but also need to load .elf file.
https://www.infineon.com/dgdl/Infineon-AURIX_Getting_Started_with_AURIX_Development_Studio-GettingSt...
dw
Di_W
Hi Ana,
dw
Ana0211
Thank you for your answer !
Do you know if there is any option that needs to be activated so that I can avoid rebuilding my project every time I debug it with Aurix Development Studio?
Thank you,
Ana
