Abdalrahman
5 likes given First reply posted First like given
I created simple C/C++ "Hello World" project but it didn't compile at all having this error message.
Kindly check the attachements
Error: An internal error occured during : "FetchJob".
Jeremy_Z
250 sign-ins 100 likes received 750 replies posted
Hi @Abdalrahman
From my experience, the issue is related to the new project itself, whether you can illustrate the steps of creating the project you did in the Aurix Development Studio.
Looking forward to your reply.
BR,
Jeremy
Jeremy_Z
Hi @Abdalrahman
BR,
Jeremy
Abdalrahman
Hello Jeremy,
I have an urgent question please:
Can you(as Infenion) provide a make file and linker script for the TC3XX family as these files are
requested from me in my project using TC3XX target but I can’t find them.
Jeremy_Z
Hi @Abdalrahman
Thanks for your reply.
There's no uniform make file and linker file, as there're lots of variants of the TC3XX series, so I'd like to suggest you download the base project package which contains the related files you want.
BR,
Jeremy
Abdalrahman
Hello @Jeremy_Z ,
 Could you please grant me an access to the (https://myicp.infineon.com/sites/microcontrollers-aurix_customer_doc/Lists/defaultdoclib/AURIX%20TC3...) as I can't access it? Kindly check the attachments.
Thanks and regards,
Abdalrahman
Jeremy_Z
Hi @Abdalrahman
Please follow the link to apply for the access authority.
BR,
Jeremy
Abdalrahman
Hello @Jeremy_Z
 I followed the steps I swear but still no reply on my email to AURIX@infenion (Kindly check the attached screenshot). Also I don't know how to be a promoted user to get access to (https://myicp.infineon.com/sites/microcontrollers-aurix_customer_doc/Lists/defaultdoclib/AURIX%20TC3...)
Jeremy_Z
Hi @Abdalrahman
Please be more patient, it actually takes some time to handle.
BR,
Jeremy
Abdalrahman
Hello @Jeremy_Z
Another question please: Is there compatibility between Tasking compiler and HiTech compiler in terms of linker, makefile and startup code? as we will use both of them in our project.
Jeremy_Z
Hi @Abdalrahman
1) Is there compatibility between Tasking compiler and HiTech compiler in terms of linker, makefile and startup code? as we will use both of them in our project.
-- No, I'm afraid it's incompatible.
BR,
Jeremy
