rdkadabi
First reply posted 5 sign-ins First question asked
Where I can find the  AURIX  3XX  DSP block diagram? Is DSP used for Motor control applications for calculations or some algorithm development?
For AURIX inverter and motor control applications do we need the DSP core?
Anupama_A
50 solutions authored 10 likes received 250 sign-ins
Hi @rdkadabi ,
Please refer to these docs and let us know if it helps with your query.
Anupama.
Anupama_A
Hi @rdkadabi ,
Anupama.
rdkadabi
I tried to access the document link above it mentions " You are not authorized to access this service".
Can you help me the link where this information is available? Can you answer the above questions on DSP that will be a great help
Anupama_A
Hi @rdkadabi ,
You can follow the steps mentioned in this link to get access to Aurix documentation.
Anupama.
