09:35 PM
Oct 30, 2014
09:35 PM
hi,
I connected the kit with DAP mini wiggler.Ran the DAS detected the target.I used the Tasking IDE to debug the target.Now the RESET D106 pin is glowing ON and OFF red. Also the light on the DAP miniwiggler is not continously ON..Has any body faced similar problem.do you think the board has gone to locked state. and what can be done to start working with the board.will it work with HighTec compiler.Does there seem to be issue with the board.
Regrads
Srividya
Regrads
Srividya
11:01 PM
Nov 03, 2014
11:01 PM
the onboard TLF resets the AURIX there it is not served.
Please contact your supplier or your infineon support for more details.
Florian
Florian
05:02 PM
Oct 29, 2015
05:02 PM
Srividya wrote:
hi,
Regrads
Srividya
How did you resolve the issue? I shorted TM on the power supply to 5 volts, which should disable the watchdog, but it didn't help.
05:03 PM
Oct 29, 2015
05:03 PM
Florian
Do you know how to resolve the issue? I shorted TM on the power supply to 5 volts, which should disable the watchdog, but it didn't help. I received this information through my infineon rep but am yet to find a solution that works.
