hi,
I connected the kit with DAP mini wiggler.Ran the DAS detected the target.I used the Tasking IDE to debug the target.Now the RESET D106 pin is glowing ON and OFF red. Also the light on the DAP miniwiggler is not continously ON..Has any body faced similar problem.do you think the board has gone to locked state. and what can be done to start working with the board.will it work with HighTec compiler.Does there seem to be issue with the board.
Regrads
Srividya
Florian
5 replies posted Welcome! First reply posted
the onboard TLF resets the AURIX there it is not served.
Please contact your supplier or your infineon support for more details.
Florian
Srividya wrote:
hi,
Regrads
Srividya
How did you resolve the issue? I shorted TM on the power supply to 5 volts, which should disable the watchdog, but it didn't help.
Florian
Do you know how to resolve the issue? I shorted TM on the power supply to 5 volts, which should disable the watchdog, but it didn't help. I received this information through my infineon rep but am yet to find a solution that works.
