AURIX™ Forum Discussions
User9635
Level 4
Level 4
50 replies posted 50 questions asked 25 replies posted
Hello Support,
Aurix 2G Watchdog Expiry event is connected to SMU Alarms which produces the required reset/NMI to CPU.
Can this connection from WDT to SMU Alarm be disabled using SMU Configuration, so that there will be no more Watchdog reset/NMI to CPU when WDT expires?
I am assuming it can be easily disabled by changing SMU AGC Registers so that CPU will continue running as normal even though WDT has expired without any service tick.
Please confirm.
4271.attach
Best Regards
NeMa_4793301
Level 6
Level 6
Yes, it is possible to maliciously reprogram the SMU registers to disable the alarm for the watchdog recovery timer, which normally causes a System Reset.
But you could only do that when the SMU configuration is not locked.
And the registers are Safety Endinit protected, so you couldn't do it by accident.
